Is this normal for tubes.
0 Members and 1 Guest are viewing this topic. Read 1388 times.
milford3
« on: 11 Jun 2011, 05:08 pm »
Pics of 6L6's after fifty hours of play.  I rolled to EL34B's.  Is this normal wear?
jtwrace
    • TIPP YouTube Channel
Re: Is this normal for tubes.
« Reply #1 on: 11 Jun 2011, 05:12 pm »
Yes it's normal.
JakeJ
« Reply #2 on: 11 Jun 2011, 08:52 pm »
milford3,
Are you referring to the slight discoloration of the flashing (silvery mirror part of glass at tube base)?  If so, then yes.
Can you post a better, ie. higher resolution, photo?  I'd like to see a better, clearer image of the area around the flashing.  It looks like a white-ish area is forming along the edge of the flashing.  This may indicate the tube is gassy (lost, low, or poor quality vacuum) and it will die an early death.  Get them tested, if you can, and definitely before putting them back in your amp!
Hope this helps.
AnalogTubes
  • Tubes and custom tube sets.
    • AnalogTubes.com
« Reply #3 on: 13 Jul 2011, 03:17 am »
This is very common to all power tubes. It does not reflect anything about their quality or longevity.
