IR Receiver
0 Members and 1 Guest are viewing this topic. Read 1135 times.
whubbard
IR Receiver
« on: 8 Jun 2011, 01:09 pm »
I've got a question that hopefully someone can help me with.
I have a Xantech 789-44 IR Connection Block and I just broke the IR receiver off the receiving cable. (I then lost the diode). Basically all I'm looking for is a IR reciever that has just 3 wires coming off the receiver. Because of my setup this is easier than one with a 3.5mm jack at the end of the cable; however, I could always just cut the 3.5mm jack off and use the wires.
I effectively want something that looks like this sans 3.5mm jack:
But is a receiver not a flasher. I also understand the receiver will be a little bit bigger, but I'm looking for the most minimalist design possible.
stigs
Re: IR Receiver
« Reply #1 on: 11 Jun 2011, 06:38 pm »
Model DL85 receiver available thru Smarthome.
