Looking for some advice, i need L + R speakers to go with my A/V-3s CC.
0 Members and 1 Guest are viewing this topic. Read 1560 times.
minisq
I am looking at the N3 tower, and have read that there is also a N3 TL tower....are they the same thing? would this be a good choice? I currently have a pair of monitor audio 2-ways on stands and they are fine, but i have had bookshelf /speaker stands for he past 30 years and i am tired of them. Would like either larger monitors, or towers. Budget is in the $700 area.
Danny Richie
Same thing. It's a transmission line design.
And they use the same woofers as your A/V-3S and will match well.
minisq
thanks danny...so basically i can choose sealed or TL and be ok with either? And when i order i should do all the upgrades available too?
I have been debating this or the swans 5.1 or 5.2...one i just open the box and plug it in...the other i get to build something...but is there a premade box available that you know for the N3 either sealed or tower?
Danny Richie
Yep.
It depends on how good you want it to sound.  :)
Ruben can build you some N3 cabinets in beautiful automotive finishes. Or Ron Joyner is pretty good with the Cherry veneer...
There is a box available from PE that can be used in a sealed application too.
