special 12v trigger adapters necessary for automatic startup?
0 Members and 1 Guest are viewing this topic. Read 868 times.
Marius
HI James,
Are special adapters necessary to use the 12v triggers?
What configuration would you recommend considering the lineup of 2 28b's, bp26/bp1.5/bmps-2, bcd-1, bda-1, bdp-1, and the 10bsub?
Would it be harmful to have everything plugged in 2 powerblocks (one connected to the other), and switch them on/off by switching on/off the first powerblock. That would prevent a whole system of trigger-wires....
I've also got the Quad ESL63's in the powerblocks.
Greets,
Marius
  • The Demo is Everything!
    • http://www.bryston.com
HI James,
Greets,
Marius
Hi Marius
You can hook up the triggers using even 22 g wire as it only carries a very small voltage. There is a delay of about 1 second if you loop the trigger wire in and out of a unit as well.
I usually set things up so the amps come on last - that way no chance of crap being amplified through your speakers.
James
