?? re space behind corner traps at 45 degrees
0 Members and 1 Guest are viewing this topic. Read 2376 times.
rlw3
« on: 3 Jun 2011, 04:05 pm »
which results in tighter and lower bass a 45 degree trap in a corner with air in the "cavity" behind the trap or filling that area with material? what material would be best? would old cloth work well??
DTB300
Re: ?? re space behind corner traps at 45 degrees
« Reply #1 on: 3 Jun 2011, 04:11 pm »
I have 4" traps across the corners (45 degree) from floor to ceiling.  When I added some Bulk Acoustical Cotton behind them, the bass response/sound improved in my room.
bpape
    • Sensible Sound Solutions
« Reply #2 on: 3 Jun 2011, 05:22 pm »
Adding more behind will help some certainly.  Cloth will do something but hard to say what exactly.  Something like insulation will work better.
Bryan
firedog
« Reply #3 on: 4 Jun 2011, 08:31 am »
So isn't that part of what Tri-Traps do?
rw@cn
« Reply #4 on: 4 Jun 2011, 12:22 pm »
As some one who is interested in Tri Traps, I would like to second the question?
bpape
« Reply #5 on: 4 Jun 2011, 02:04 pm »
Yes.  The Tri Traps are a solid chunk style absorber rather than a 4" panel straddling.  They fill the entire corner at 17x17x24".
Bryan
