0 Members and 1 Guest are viewing this topic. Read 18771 times.
Hey! The past 11 years I've been using KR Audio tube in my SET amps of which are design to run KR Audio 300BXLS or 842VHD tube. The price of these tubes have gone through the roof. These are special tubes and I remembered there were one other company the AVVT that made tube that can be direct sub for those KR mentioned. But I think they are now gone. But came across the Emission Labs. I've heard about them before but I didn't know they do have direct sub for the KR 300BXLS. And the price is lower too! So, dose anyone here using or have used Emission Labs tube? How is the sound and build quality?http://www.emissionlabs.com/index-en.htmTake care,Buddy
If you buy tubes and recieve them with open filament you ought to send a complaint to the seller and ask for a replacement tube or money back. Did you buy your tubes from an approved KR dealer? If so you have a warranty! If not......For more information http://www.kraudio.com/images/stories/doc/Warranty.pdfKind regards
.....EML posted a good article on burning in new 300Bs. I recommend that you read it even if you don't buy their tubes. (All of their articles are worth reading.) Also, make sure that your amplifier can supply more than 1.25A of filiment current if you decide to deviate beyond the standard Western Electric 300B tube specification. If you don't know which to get, just stick with the standard 300B tube.
Actually I can't use regular 300B in my amps My SET Monoblocks were designed around what was then a brand new high power variation of the WE300B, the KR 300B-XLS. These SETs operate at higher voltage to get more power, 18 watts per channel in this case. And they won't have problem supplying higher filament current since they were meant to be use with these special tubes.
