Industry Circles
Audio by Van Alstine
jimava
Looking for additional high quality analog to digital converters.....
0 Members and 1 Guest are viewing this topic. Read 2070 times.
Wayner
1 Jun 2011, 08:20 pm »
A fellow ACer asked me to help him find an appropriate analog to digital converter so he can eventually get his TT into his digital preamp. Of course, he needs a quality phono preamp (like a nice Insight+, from AVA) which would n turn feed the ADC and then off to his digital input only preamp.
I found a couple:
from Amazon:
http://www.amazon.com/Gefen-GTV-AAUD-2-DIGAUD-Analog-to-digial-Audio-Adapter/dp/B001ED2UTG
and this one:
also from Amazon:
http://www.amazon.com/gp/product/B0045UWXB0/ref=pd_lpo_k2_dp_sr_2?pf_rd_p=486539851&pf_rd_s=lpo-top-stripe-1&pf_rd_t=201&pf_rd_i=B001ED2UTG&pf_rd_m=ATVPDKIKX0DER&pf_rd_r=0TQJN6ABTEDH89ZJX658
Any other models would be welcomed as a information source.
Thanks, men.
Wayner
AVnerdguy
Re: Looking for additional high quality analog to digital converters.....
1 Jun 2011, 08:37 pm »
Art USB Phono Plus V2 Phono Preamp w/ USB Connectivity (and TOSLINK)
About $70 on the web. Decent quality and does line level and phono - until he gets that AVA phono pre!
You can download the manual at
http://www.artproaudio.com/products.asp?type=90&cat=13&id=110
Wayner
Reply #2 on:
1 Jun 2011, 08:39 pm »
I don't think any computer is involved so I'm not sure of that unit's capabilities without a USB interface......
Wayner
AVnerdguy
Reply #3 on:
1 Jun 2011, 08:50 pm »
OK, too bad. It really is a neat little unit and surprisingly good phono section
Wayner
Reply #4 on:
1 Jun 2011, 08:57 pm »
Well, I'm not totally sure, but I am suspicious. Maybe someone is using it here.
Good input, others may use it for other reasons.
Wayner
AVnerdguy
Reply #5 on:
1 Jun 2011, 09:03 pm »
I believe I saw it in Cheap & Cheerful awhile back.
Industry Circles
jimava
