SOLD : Brocksieper TriMax Amps
0 Members and 1 Guest are viewing this topic. Read 1829 times.
LostInPA
« on: 30 May 2011, 07:09 pm »
I have four of these 25 Watt Class A mono amps.   These are the LC807/25 variant listed at the bottom of the Amplifiers page at the Brocksieper site http://Brocksieper.com.  Tube complement is (1) 12AT7, (1) 12AU7, and (2) 807.   Each of these amps is now fitted with (1) JJ ECC81, (1) JJ ECC802S, and (2) Sylvania 5933WA.   These amps are a few years old, and are just basic boxes approx. 9 1/2" W x 7 1/2" H x 17" L.   No operational issues, and only minor cosmetic issues for age.   Note that these amps require you to use a meter and a steady hand in order to separately adjust the bias of the two output tubes.   The output transformer is a single tap for 4 - 16 ohm loads.   One pair of these was used by the dealer in his home system, and the other pair was new when I purchased them.   Asking $850. for the demo pair and $925. for the other pair, or $1,725. for both pair.   A mixed lot of approx (20) used 807's plus approx. (14) used 5933's will be included with the first pair to be sold;  approx. (14) used 5933's will be included with the second pair sold.   From ZIP 18661.
« Last Edit: 15 Jun 2011, 06:15 pm by LostInPA »
