black and white
0 Members and 1 Guest are viewing this topic. Read 25803 times.
studiotech
Re: black and white
« Reply #80 on: 2 Jul 2011, 04:25 am »
Pretty neat.  I'm note sure if it looks more like haunted house spider webs or Japanese rice paper.  What is the product?
Greg
brian t
Re: black and white
« Reply #81 on: 3 Jul 2011, 06:53 pm »
yes its definately an aquired taste, what we have to do for domestic harmony ! its a marble effect spray paint you get from most diy stores it is applied over a base coat in my case it was white paint applied over the black it takes a bit of practice to apply it right i then put some laquer on afterwards to seal it.
JohnR
Re: black and white
« Reply #82 on: 4 Jul 2011, 07:58 am »
Where did the bolts go?
brian t
Re: black and white
« Reply #83 on: 5 Jul 2011, 07:15 pm »
If you mean the ones for the tangband driver i am making some ali plates for them to brace against then i will refit
JohnR
Re: black and white
« Reply #84 on: 6 Jul 2011, 02:00 am »
Oh, I see what you're doing now, i didn't quite get it before. The bolts are just pushing on the magnets, they're not actually attached to them. Very clever :thumb:
