Dual SW-12-08 woofer enclosure
0 Members and 1 Guest are viewing this topic. Read 2259 times.
Hemiar
« on: 29 May 2011, 05:59 am »
Does anyone have a link to a dual SW-12-08 woofer enclosure? I have seen a few designs, but I cant find an enclosure design diagram complete with mesurements.  Thanks!
Danny Richie
Re: Dual SW-12-08 woofer enclosure
« Reply #1 on: 29 May 2011, 06:38 pm »
Take the standard box for a single woofer: http://www.gr-research.com/pdf/singleservo.pdf
The cut one side wall off of it and put it right up against another complete box. Now you have all the measurements. Then make the top/bottom and front/back baffles a common single piece.
You can go the same with the sand box design too: http://www.gr-research.com/pdf/sandbox.pdf
Danny Richie
« Reply #2 on: 29 May 2011, 06:39 pm »
And Hemiar, welcome to AC.  :thumb:
Hemiar
« Reply #3 on: 31 May 2011, 12:03 am »
Thanks Danny. I frequent these posts, but havent posted until now. That will change.
By the way, the N2x fronts and backs with the N3S sound great with the SW-12-04! I will post pics of my system soon. I've only had them for 2 months and I already have someone who is dying to buy them off me. I guess I will have to upgrade soon.  :D
john garnet
« Reply #4 on: 31 May 2011, 12:32 pm »
Hi All,
I'm looking forward to following this thread as I too am about to build a dual SW-12-08 sub to pair with a pair of Cornscalas I'm also about to build. I'm even contemplating building a second dual SW-12-08 sub as well. Maybe overkill, but I do like bass! Can anyone tell me that's a bad idea?
Hemiar
« Reply #5 on: 1 Jun 2011, 12:55 am »
well I am by no means an expert by any strech, but I would recommend that when deciding on how many subs to use with any given system you must take into account all the variables (room acoustics/size, system pairing with, etc...) and what your are going to use the system for (theater room, music type, personal tastes, etc...). For most setups (small to mid size) two subs are plenty, but if your going large, 4 can work.
Hemiar
« Reply #6 on: 1 Jun 2011, 01:20 am »
