Emotiva upa-2 power amp SOLD SOLD SOLD
0 Members and 1 Guest are viewing this topic. Read 952 times.
gnars
« on: 27 May 2011, 07:08 pm »
UPA-2 POWER AMP
EXCELLENT COND. WITH ORIGINAL BOX, PACKING, MANUAL, POWER CORD.
LOOKING FOR 299.00 shipped US 48
WITH FREE BRAN NEW PANGEA AC 14 POWER CORD @ ASKING PRICE
WILL SHIP TO CANADA VIA USPS ONLY. EMAIL WITH POSTAL CODE FOR COST
UPA-2 Two Channel Power Amplifier. Perfect as a stand-alone stereo amplifier, building block in a growing system, or zone amp. Daisy-chain capable, with a volume control.
Power output:
• 8 Ohms = 125 watts RMS per channel (2)
• 4 Ohms = 185 watts RMS per channel (2)
• Frequency Response: +/- 0.1 db: 20 to 20Khz
• Broadband Frequency Response: -3db 10hz - 150khz
• Signal to Noise Ratio: (Un-weighted): >100db
• Distortion (THD, 80Khz bandwidth): 0.007
• Discrete, dual differential class AB amplifier topology with active current sources
• Low noise toroidal power transformer
• On Semiconductor output devices
• Damping Factor: Approximately 200 into 8 ohms
• Gain: Channels : 32db
• Input Impedance: 47K ohm
• External Trigger: 3-12 Volts DC (tip positive)
• DC Offset: 75db
• Fully protected from all fault conditions
• External trigger input/output (3-12 Volts DC - tip positive)
• Output/Level control
• Preamp in/out loop for daisy chaining
• Soft touch power switch
• 2RU chassis w/ solid milled aluminum faceplate
• IEC power inlet, 120/230 VAC configurable
•17” W x 3 7/8” H x 13” D
sold
« Last Edit: 11 Jun 2011, 10:54 pm by gnars »
