Anyone try a Pacific Pro Audio hard drive?
0 Members and 1 Guest are viewing this topic. Read 1120 times.
rpf
« on: 27 May 2011, 07:03 pm »
http://www.pacificproaudio.com/drives1.asp
Uses the Oxford 934 chipset and supposedly developed for A/V use.
Berto
Re: Anyone try a Pacific Pro Audio hard drive?
« Reply #1 on: 28 May 2011, 03:30 am »
doesnt tell you what mfg makes there drive or what the price is.
Im trying  a gtech drive w/same chipset, hitachi drive, quiet and reliable so far, course when ssd is under 300 for 2tb then that will be a consideration
rpf
« Reply #2 on: 28 May 2011, 04:28 am »
No, they don't tell you who manufactures the drive but the price for the 2tb model is $245 as shown here: http://www.pacificproaudio.com/drives.asp
About the same price as the Gtech but has a shorter warranty. One year for the Pacific; three years for the Gtech, which also has a 3tb model.
Thanks for the tip.
Berto
« Reply #3 on: 28 May 2011, 04:45 am »
welcome, plus quick , free tech support doesn't suck either. :thumb:
