0 Members and 1 Guest are viewing this topic. Read 13504 times.
Russ, if you have the RM30C, there is no active 10". That's the 30M, and you add the 10uF cap to compensate for the lower impedance of the circuit when the active 10" is taken out. The xover frequency does not change.Bob, the active 6.5" are now in parallel, for a 4 Ohm load. That's plus to plus and neg to neg and both woofers.
The RM30 has been our most popular model since its introduction in 2004. Newport is our first consumer show in several years, and I wondered what I could do to improve system performance, now that the second generation of CDWG's is standard on all our planar speakers.As it turned out, all that was necessary was a small change from dual 6" slot-loaded passive radiators to a single side-firing, vitrified cone 10" PR with double the Xmax of the old ones. The system looks the same as the RM 30M, but its active 10" is replaced by the new passive, with suitable retuning and xover adjustments. Intro price will be $3500pr in piano black with inboard analog crossovers. The outboard analog OXO adds $450, and if you want to biamp and go digital, as we will in Newport, two versions of the DCX 2496 are available at $900 and $1600. The highly modded costlier version will be on display, biamped through Ampzilla electronics and Nuforce/Wyred4Sound DACS.I think audiophiles will be amazed by the sonic performance of this setup. Visit us in Rm 411 and hear for yourself.
I would be willing to convert my RM30M to the upgraded version, but I would want photographic step by step instructions. Monsterbill does, too. I suspect many RM30 owners would appreciate this bit of extra effort on Brian's part. After all, he has now made us less than perfectly satisfied with our previously wonderful speakers!
Am I correctly following this mod? Replace an ACTIVE 10" with a 10" PR improves the performance?I must be missing something.....
No, it replaces the two six inch downfiring passives.
I'm not quite following on the woofer wiring. I get that the 6.5 inchers are parallelled, but how is the 10" (think M here) wired in? Since you mentioned series parallel, I thought the 10" was in series with the conjugate 6.5"., which would mean 6.5 neg to 10 pos. Is that not the case?
