0 Members and 1 Guest are viewing this topic. Read 8690 times.
I think I am going to sell everything and by a Wave Radio plus lots of beer...
That all said I get SOOOOOOO much more satisfaction out of things when I build them. Plus I like using tools and shit. I will still build stuff just maybe not as much. I guess I had a really lucky stretch where everything worked pretty well.
I think what I need is a cheapish well defined speaker project. I need to get away from single drivers. I just can't get the output I need to get down. I have all this BB ply in my garage calling my name. Like a crackhead if the last fix don't work keep going. I'm sure the next will....
Maybe you should try an open baffle project, rather easy to do. A DCX helps there.
my problems WERE the DCX. I bought one, returned it to seller. Bought a 2nd one, seemed fine, but couldn't hear the bass issue since it was just used on tops, at the time, now its back in the box...I still have unfinished ob subs because i have no workspace.I still have a crapload of tubes and insulation for absorber testing... the good news? It is in my sister's basement, instead of my own!-Tony
Wave Radio? Nonononono. That's like switching to methodone.You need to keep it real.The glasses comes with the blaster. At least, they should.
I will be seeing Primus at Bonnaroo this year. Uncle Les will help me vent I am sure...
