Audio/Video Gear and Systems
The Lab
sts9fan
Need help removing caps
0 Members and 1 Guest are viewing this topic. Read 1817 times.
Nikko
31 Jan 2003, 05:49 am »
The large input caps on my Melos SHA Gold Reference preamp are sitting in a substance that looks like wax. Can anyone identify what this substance is and how to remove it without damaging the board?
mgalusha
Just a geezer.
31 Jan 2003, 02:05 pm »
Nikko,
It's very likely hot melt glue. You can soften and remove it with a heat gun. Of course you don't want to get anything else too hot but with care you should be able to remove it.
Of course if it's not hot glue, all bets are off.
Mike
Nikko
Reply #2 on:
31 Jan 2003, 08:32 pm »
Looks like it's some kind of thermal adhesive, possibly Loctite. There must be some kind of solvent to remove it. Anyone know of a solvent to remove this stuff without damaging the PCB?
The Lab
sts9fan
