Is There a Good DCX2496 DIY Out There?
0 Members and 1 Guest are viewing this topic. Read 2838 times.
gongos
« on: 21 May 2011, 07:13 pm »
Anyone have a good link for a diy setup? Trying to use one with my Revelations?
TomS
Re: Is There a Good DCX2496 DIY Out There?
« Reply #1 on: 21 May 2011, 07:37 pm »
Yes, many, many threads... Just a couple here.
http://www.audiocircle.com/index.php?topic=47777.0
http://www.diyaudio.com/forums/digital-line-level/15943-behringer-dcx2496-digital-x-over.html
I did the same mods as Mike and think that is the best way to go but it depends on what you want do.
gongos
« Reply #2 on: 21 May 2011, 08:55 pm »
should've been a little more clear.  I'm not looking to mod one,but integrate it inti my system, ie setup the curves or any room correction.
« Reply #3 on: 21 May 2011, 09:01 pm »
The miniDSP 2x4 is what you are looking for...
panomaniac
« Reply #4 on: 21 May 2011, 09:14 pm »
The DEQ2496 is more suited to curves and room correction.  The DCX is a crossover.  (I use both).  What do you want to do with it?
TomS
« Reply #5 on: 21 May 2011, 09:28 pm »
Oops, sorry, my reading comprehension must be poor today  :duh:. Bob could probably guide you on the crossover part, though I recall he isn't keen on active. EQ, measuring, is an art in itself.
Bob in St. Louis
« Reply #6 on: 22 May 2011, 12:10 am »
If I'm the Bob you're talking about, then "YES", I've removed as much responsibility as I possibly could regarding what the DCX has control over. It just sounded like crap compaired to quality passive components.
If I'm not the Bob, then.....um.....pardon....  :wink:
Bob
