Newbie to HT - advice for options w/a PS3
0 Members and 1 Guest are viewing this topic. Read 1512 times.
gooberdude
« on: 21 May 2011, 05:55 pm »
I'm not well versed in HT & need some advice.  My blu-ray source is a new PS3, and i'm uncertain as to which (dac or ht preamp/processor) is the right decision for my situation.
I have a 2 channel tube system w/subs, the subs get their signal from speaker level inputs off the amp.
Should I find a decent dac w/optical inputs for the ps3, or find an av preamp to take the signal in hdmi, in order to take advantage of dts-hd,  dolby true hd & other hi-rez material?
I use a tranquility nos dac for music duties & have a multi-function preamp already.
My budget is limited for this purchase $750 or less
I plan to purchase a 1080p projector soon, but have a 2 channel system for some time & prefer a processor w/no amplification & volume bypass).
any assistance is appreciated.
matt
Mr Peabody
Re: Newbie to HT - advice for options w/a PS3
« Reply #1 on: 1 Jun 2011, 03:22 am »
It sounds like you are heading into home theater, I personally would keep your 2-channel system separate.  When I first went to tube gear it did not mesh with my solid state, I had to go down two roads myself.  My two systems do share the main speakers, I just manually switch speaker cables at the back of the speaker, a breeze with bananas.
In your given budget, unless buying used and getting old technology, not really recommended, you should buy a receiver with preamp outputs and use it as a preamp to an outboard amp array.  Second thought, if you act quickly Emotiva is blowing out their UMC-1 for under $600.00, preamp processor.  From there marantz, Onkyo & Rotel start clocking in around the $1500.00 mark for a passive HT processor.  The PS3 is a good move, games & movies, easy upgrades and still a very good Blu-ray player.
« Reply #2 on: 1 Jun 2011, 03:13 pm »
Will you be going to surround sound with 5  or 7 speakers?
HT cOz
« Reply #3 on: 4 Jun 2011, 06:10 pm »
Outlaw has Marantz SR50005 for $549. It has pre amps out.
That could be an option if you are starting to get more into HT.
