B100 Plastic Covering Output Binding Posts
0 Members and 1 Guest are viewing this topic. Read 944 times.
headshrinker2
« on: 20 May 2011, 04:41 pm »
Received my S/H B100-SST today.  Doing initial setup and testing.
A question about the output binding posts.  Are the clear plastic pieces just for protective purposes during shipping, or are they supposed to stay in place during use?
Thanks.
  • The Demo is Everything!
    • http://www.bryston.com
Re: B100 Plastic Covering Output Binding Posts
« Reply #1 on: 20 May 2011, 04:51 pm »
Thanks.
STAY IN PLACE.
james
Stu Pitt
« Reply #2 on: 20 May 2011, 07:31 pm »
You're probably used to Naim's speaker connectors.  The binding posts on Bryston (and pretty much everything else, except Linn) unscrew a bit but don't come off.  They unscrew a bit to allow spade lugs or bare wire - insert the bare wire through the hole that runs perpendicular to the shaft, then tighten the binding post back down.  To use spades, unscrew the post a bit, fit the spade against the back, the tighten the post.  For banana plugs, remove the plug from the center of the post (if you're looking at it straight on), and push the banana plug it.
Bare wire and spades offer better contact than bananas in my experience.  I use spades because the clapm down pretty good and keep everything tidy.
Stu Pitt
« Reply #3 on: 20 May 2011, 07:33 pm »
I'd be interested in a comparison of the B100 vs Nait XS once you've got everything running and get used to what the B100 is doing.
