Hi Steve,
I have used the tall Tenderfeet in the past, and have moved more recently to the turntable Isoball setup in conjunction with grungebuster dots isolating the shelf from the rack. I appreciate the different sound that the Isoballs produce with my Rega P5, but it isn't quite as good for vibration isolation as the Tenderfeet. Neither have been able to completely absorb the floor-borne vibrations, but the Tenderfeet did a pretty good job (about 90%).
I have recently changed my cartridge to one that has better low frequency performance, and unfortunately, this has also accentuated the rumble that I get from the nearby light rail trains. Do you have any suggestions for industrial-strength vibration isolation? Unfortunately, I can't mount the table on the wall, as there isn't room to do this without contorting to play a record, which will likely take the fun out of it.
I am willing to consider such devices as Ginkgo Clouds or a DIY box, but this will also likely raise the turntable to a height that will make it difficult to play records, however, this is probably more doable than the wall mount option.
Any thoughts appreciated! Big fan of your products!
Wilson
