advice on an OB project
0 Members and 1 Guest are viewing this topic. Read 3125 times.
077 tweeter
« on: 20 May 2011, 02:34 pm »
I want to use old jbl 12" d123 extended range speakers on an OB.I might use a subwoofer. The d123's go out to 7kc,where I add jbl 077 horn tweeters. The d123's are 98 db efficient,fs of 40hz,qts of .45,and a vas of 4.5 cubic ft. What size OB board should I use? should it be flat only,or use wings? Thanks for any advice.Rudy( 077 tweeter).
DanH
Re: advice on an OB project
« Reply #1 on: 22 May 2011, 03:44 am »
See these sites. They are a good starting point:
http://www.quarter-wave.com/
http://members.myactv.net/~je2a3/open.htm
Badwater
« Reply #2 on: 23 May 2011, 12:34 am »
I did a similar project with and EVSP12B.  I am very satisfied with the result.
Sp12b high passed at 200 hz passive.  Fostex t90 with a cap very high and Alpha 15A in an H frame driven by a low powered plate amp.  This sounds way better than it should.
Bill
http://gallery.me.com/marilynladieu#100295
scorpion
« Reply #3 on: 24 May 2011, 11:29 pm »
Actually, I don't think Bill's outfit could be any bettered at all.
/Erling
Badwater
« Reply #4 on: 25 May 2011, 10:31 pm »
Thank you Erling.
The next phase of the project is to implement a MiniDSP and upgrade the amps driving the Alphas.  i built a 4 Channel Class D Audio kit to do this.  The amp is wonderful.  I just have figure out how I am going to sneak everything into the living room without my wife noticing.
scorpion
« Reply #5 on: 27 May 2011, 03:01 pm »
My be I should have been a bit more articulate.
I think the adding of an H_baffle bass is a very sound idea, because you would never be able to regain bass OB-wise with this JBL-unit.
So H-bass or some ohter U- or unit flat OB based could be fine.
About the EV-units I have no real idea how they sound.
/Erling
Badwater
« Reply #6 on: 28 May 2011, 01:55 pm »
I second Erling on the H-Frame.  Add a good tweeter to your JBL and you should be in for a treat.
The EVSP12B units or ElectroVoice are vintage drivers that I bought new in 1975.  They literally have 1000s of hours on them.  To my ears they are every bit the equal to a pair of Fostex 166ESR that I have. I have enjoyed them very much over the years.
