Sold!! FS: Aric Audio 3.7 Tube Preamp, possible extra tubes and Shunyata PC!
0 Members and 1 Guest are viewing this topic. Read 3047 times.
starkiller
Well, once again I learn the hard way. I found out I needed a preamp w/tone controls for the system in the garage so the Aric is up for sale or trade. Here is the info from the site:
"Flagship Model 3.7 preamplifier
Flagship, completely handmade (by myself) Stereo Preamplifier, featuring twin 12au7's, with high-current power switches, tube guards, 3 sets of stereo inputs with source switch, Audio Taper volume and trim controls, 2 sets of r.c.a. outputs (all gold-plated r.c.a.'s), high-current, switchmode power supply and overall robust, bulletproof construction with updated circuitry. 2.0 volts output per channel R.M.S., 10-30,000hz, 100kohm input and 10kohm output impedances. Also compatible with 12at7, 12ax7, 12ay7 and 12az7. Zero noise, or hum at idle and high-end Dayton Metailized polypropelene signal capacitors, along with all metal-oxide resistors in the signal path ensure clean, dynamic, and smooth audio at all freuencies. This gem works with solid-state amps, tube amps, receivers, and as a Tube buffer for multiple purposes. The power supply will work anywhere in the world! It is a digital, regulated supoply and will accept any voltage from 110-240 VAC! The included plug is a 3-prong for North American use, but you simply swap the detachable cord for one that fits your mains where you live."
I will include a set of RCA orange print 12BH7A's and depending upon the trade and or price, might also include a set of JRC black plate triple mica 5814a's, a set of Miniwatt ECC82's, a set of Mullard 8136's and possibly a Shunyata Venom 3.
Selling price is $350 shipped CONUS. Trade ideas would be a nice SS amp with no sound issues, bad cosmetics are fine though :green:
« Last Edit: 2 Jun 2011, 05:33 am by starkiller »
Bemopti123
I sent you PM.
starkiller
PM replied to...
toot123
another pm
starkiller
