0 Members and 1 Guest are viewing this topic. Read 5363 times.
These have a very long story associated with them. The short of it is I bought them off of a dude on another forum. This was before AE was back in business making these drivers. They are slightly different in appearance to the newer TD15X but supposedly measure the exact same. I have a WT3, so I can test the free air parameters but I can't easily test the VAS.I had bought 4 of them of the dude. 1 was completely destroyed and I no longer have it. Two got reconed as their cones were ripped to shreds. The last one I still have but the voicecoil rubs on the pole piece. Apparently it can be repaired, but it isn't easy to do. I do have the instructions saved on my computer "somewhere", but it basically involves trying to pry the backplate of the magnet up and shim it until you can slowly work the plate back to center so the pole piece which is attached to the backplate is centered again. The magnets are so strong that it is going to be very hard to pry. So the deal is, I am taking best offers on the two re-coned TD15Xs and the third will be a freebie if you want it. Otherwise I'll give it away to someone else (buyers of the two gets first dibs). All in all I paid as much as new for these because I wasn't compensated at all by the buyer (except a tiny bit that didn't even pay for the re-coning). They newer ones are $260/ea, but these are a little more of an unknown since with the re-cone the T/S parameters could have shifted a little. These will still have the amazing motors and the cones should be very similar. Millersound did the excellent work on the re-coning, fyi.
