Speakers and ohms
0 Members and 1 Guest are viewing this topic. Read 983 times.
johnst
Speakers and ohms
« on: 18 May 2011, 01:14 pm »
Maybe this is not easily answered but my question is this: If my amp is rated at 80 wpc into 6 ohms, is it more desirable to buy speakers rated at 4 0hms or 8 ohms? Thanks in advance for any responses. John
koyaan
Re: Speakers and ohms
« Reply #1 on: 18 May 2011, 04:33 pm »
8 ohm speakers wouldn't work the amp as hard as 4 ohm speakers, though you probably won't still get 80 watts per channel with 8 ohm speakers.
Either one should work fine if played at reasonable levels.
« Reply #2 on: 18 May 2011, 05:50 pm »
Hi John,
Several aspects need to be considered. Will use tube amps as an example since you use power output at 6 ohms, an unusual spec.
1) Distortion specs are probably given with a 6 ohm resistive load.
2) As you know speaker impedance varies across the audioband. An 8 ohm speaker can easily dip below 6 ohms at some frequency(ies) and rise well above 8 ohms, and a 4 ohm speaker can easily dip below 3 ohms and rise well above 4 ohms.
3) I will say "usually" as the load "resistance" increases, power output decreases. Harmonic and IM distortion also decreases. In general driving an "8 ohm" speaker should cause less harmonic and IM distorton than using a "4 ohm" speaker.
4) The damping factor will change. The damping factor will be higher using the 8 ohm speaker than using the 4 ohm speaker. Around bass resonance, this is a probably true as well, but I will not say "always, 100%".
5) Soundwise, you will just have to audition with both and see which you like better.
Cheers.
