832 Stereo Tube Amplifier Push Pull 6201 12AT7 5Y3
0 Members and 1 Guest are viewing this topic. Read 6051 times.
waamamps
    • WaamampS
« on: 17 May 2011, 11:42 pm »
100% Hand built push-pull, stereo all tube power amplifier using 832, 12AT7 and 5Y3 tubes. This amplifier layout has been carefully designed using a combination of Vintage, and high quality components. These high quality components are brand new and consist of Triad filter choke, Hammond power transformer, Illinois capacitors, carbon resistors, gold-plated RCA jacks, speaker jacks, top grade ceramic tube sockets, IEC connector and power switch. Illinois electrolytic capacitors are used in the cathode section and Cornell-Dubilier electrolytic capacitors are used in the power supply section. Vintage Marantz dual stereo volume control was used and in the input stage, gold plated shielded wire was used. All components are perfectly matched left to right for proper channel balance. This amplifier is all handwired, with point to point circuitry, using less wire, which allows this amp to run continuously, with extreme quiet operation. This amplifier has built in volume control and can be used with or without a preamp. You can connect any fixed or variable source output directly to this amplifier. You can use the audio out from an iPod, CD, DVD, MP3, Computer, TV, XM or SIRUS to the input connection. Amplifier was designed utilizing five tubes, one 12AT7 (Input) can be substituted with 6201, 12AU7, 12AX7, 5963 two 832 (Output) and one 5Y3 (Rectifier). This amplifier features one pair of input, volume control, power switch, power indicator, right/left speaker terminals (8 Ohms) and circuit protection. Amp works great into any 4 and 8 ohms speakers.
 Specifications:
Input connector - One pair of input.
Built in volume control and can be used with or without a preamp.
Tubes: 2-832 (RCA), 2- 12AT7(RCA) and 1-5Y3 (GE)
Input Impedance: 100K ohms
Load Impedance: 8 Ohms
Power Output: 7 Watts x2 (14 watts Total)
Dimensions: W 13 1/2" x D 11 1/2" x H 2 1/2"
For more information please visit: www.waamamps.com
Email: [email protected]
« Last Edit: 17 Jun 2011, 12:36 am by waamamps »
