IB1 Center Questions
0 Members and 1 Guest are viewing this topic. Read 2094 times.
jethro
« on: 3 Apr 2004, 11:58 pm »
James,
Will the Powerpak SST 300 fit the IB1 center (if ordered with the pre-drilled holes) ?
Are all IB1 center's magnetically shielded ?
Thanks.
  • The Demo is Everything!
    • http://www.bryston.com
« Reply #1 on: 4 Apr 2004, 12:51 pm »
Hi Jethro,
PMC use to predrill the speakers for the IB1's but they do not any longer.
Yes the IB1 Center is sheilded and that is why it is a little more expensive the 1/2 the pair.
james
jethro
« Reply #2 on: 4 Apr 2004, 03:50 pm »
James,
Do they still pre-drill the regular IB1 ?
(Mine are pre-drilled, just thinking for the future)
Thanks.
« Reply #3 on: 4 Apr 2004, 08:05 pm »
Hi Jethro,
No - they found the cost of predrilling was not worth the small number of units they sold where customers attached the amplifiers.
james
