Anyone getting a Z68 motherboard?
0 Members and 1 Guest are viewing this topic. Read 1504 times.
jqp
« on: 14 May 2011, 02:40 am »
This is the Intel chipset for the new Sandybridge CPUs. The Z68 allows you to overclock, use a discrete video card, AND use the Quick Sync technology.
Here are 15 models
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007627%20600093976%20600158412&IsNodeId=1&name=Intel%20Z68
pjchappy
Re: Anyone getting a Z68 motherboard?
« Reply #1 on: 15 May 2011, 05:41 pm »
I'm going to wait and see the performance of the AMD Bulldozer.  Would likely get another top-of-the-line ASUS MB for that one.  If the performance isn't there, I will go the SB route.  Shooting for an upgrade at the end of the year. . .and then making my current PC a 100% dedicated HTPC.
Paul
Noseyears
  • SS-Audio
    • Supreme Sound Audio
« Reply #2 on: 17 May 2011, 02:13 am »
Man, i'm also waiting for it. No release date yet?
pjchappy
« Reply #3 on: 17 May 2011, 11:14 pm »
June 7. :thumb:
If you want to continue BD talk, please do so here (so as not to hijack this one any further):  AMD Bulldozer.
Gracias!
Paul
rob-fi
« Reply #4 on: 26 May 2011, 11:24 pm »
The ASUS P8Z68-V Pro is getting good reviews everywhere, it is worth checking if somebody is considering to buy a Z68 board.
