Geddes Pioneer Receiver on VMPS
0 Members and 1 Guest are viewing this topic. Read 2861 times.
monsterbill
  • **Click the URL (globe icon below) to see my audio set ups:*
    • My audio set ups:
« on: 11 May 2011, 07:52 pm »
Okay, now that I know that the treble/mids on my RM30Ms can be run by an amp rated only for 8 Ohm loads (Thanks Steve!), I was wondering if anyone has tried the Geddes Pioneer Receiver on VMPS speakers?
This amp is discussed in this venerable thread, started by the former VMPS dealer from whom I bought 3 pairs of VMPS speakers, Jim Romeyn:
http://www.audiocircle.com/index.php?topic=68889.msg942701;topicseen#new
Jim has good ears, so I trust what he's hearing there.  According to Jim, the Pioneer amp sounds like crap with speakers <8 Ohm, which would rule out my speakers, except in a bi-amp configuration.
Anyone taken the $200 challenge and tried the Pioneer chip amp?
Pez
Re: Geddes Pioneer Receiver on VMPS
« Reply #1 on: 11 May 2011, 08:13 pm »
hard to think of a reason someone would use a receiver to bi amp, but if you're looking for cheap watts the pioneer might be the way to go.
Russtafarian
  • Typical reaction to the music I play
« Reply #2 on: 11 May 2011, 09:35 pm »
The mid/tweeter drivers on the RM30 are an easy 8 ohm load to drive.  So you'll get the best possible performance out of the Pioneer's amps.  A low to mid power tube amp will sound even better.
monsterbill
    • My audio set ups:
« Reply #3 on: 12 May 2011, 12:19 am »
I was thinking I would use the Pioneer only for the top end, to supplement my class a/b ss amp which I would relegate to the bottom in this experiment.
My current amp is actually pretty good, so this would only really be a benefit if the Pioneer is a freak aberration of talent in a sea of mid-fi, as Romeyn is claiming.
I'll search the archives for more on low-pass filters before I go forward.
« Reply #4 on: 12 May 2011, 12:37 am »
Chip amps and planar speakers don't mix well, IMO.  Better to get a moderately powered tube amp for the mids/highs and a big SS amp on the woofers.
sts9fan
« Reply #5 on: 12 May 2011, 12:48 am »
"the geddes"
monsterbill
    • My audio set ups:
« Reply #6 on: 12 May 2011, 02:31 am »
Yeah, I hear what you're saying about tubes--just not in a position to go in that direction yet.
Do you not like chip amps (for this purpose) in particular, or also not tripath/ice amps?  Personally, I've found the latter too lacking in mid-range presence, even when compared to good traditional solid state.  But I heard, years ago, that chip amps *could* be made to overcome this shortcoming.  Also, it's been years since I last spoke with Jim R., but as I recall, he had been a big tube buff for decades.  I'm curious about the switch.
« Reply #7 on: 12 May 2011, 03:15 am »
I've not heard the pioneer, but I'd be very surprised if this was the case.  Chip amps have other strengths, but midrange bloom is not one of them.
Pez
« Reply #8 on: 12 May 2011, 03:26 am »
As a tried and true low powered SET dude I will say from 1st hand experience, VMPS speakers, when freed from the bondages of passive crossover components, thrive off of low powered tube amps. I'm talking 5 watts for the mids 1-2 watts for the tweet and whatever beastly solid stte amp you can get for the woofers. This is where Things really start happening. So if you're not in a position to go tubed yet get yourself there as fast as you can.  :)
