Bi-Amp Question
0 Members and 1 Guest are viewing this topic. Read 1236 times.
monsterbill
  • **Click the URL (globe icon below) to see my audio set ups:*
    • My audio set ups:
Bi-Amp Question
« on: 11 May 2011, 05:27 pm »
I'm thinking about passively bi-amping my RM30Ms.  The impedance description on VMPS website is "Sensitivities/Impedances: Ribbon array about 93 dB / 8 Ohms, bass section about 91 dB / 4 Ohms."
Does this mean that, in a bi-amp configuration, the bass amp will be seeing a 4 Ohm load, while the treble/mid amp will be seeing an 8 Ohm load?
srb
Re: Bi-Amp Question
« Reply #1 on: 11 May 2011, 05:45 pm »
Yes.
Russtafarian
  • Typical reaction to the music I play
Re: Bi-Amp Question
« Reply #2 on: 11 May 2011, 09:29 pm »
If you really want kick-ass results, put a line level 12db per octave low-pass filter @280hz in line with the bass amp and bypass the RM30's internal woofer coil.  This can be done either passively or actively.
A little more effort than passive bi-amping but a significant increase in woofer clarity and control.
