Panny XR45 vs XR50
0 Members and 1 Guest are viewing this topic. Read 2875 times.
Richard U
Panny XR45 vs XR50
« on: 3 Apr 2004, 04:45 pm »
Everyone seems to be out of stock of the XR45 but I've seen J&R list the new XR50. Does anyone know how it differs from the XR45? No info on the Panny site. Thanks.
Richard
Richard U
Panny XR45 vs XR50
« Reply #1 on: 8 Apr 2004, 07:48 pm »
Just ordered the XR50. Will post my finding.
Richard
Richard U
Panny XR45 vs XR50
« Reply #2 on: 14 Apr 2004, 06:11 pm »
The XR50 finally arrived. I had hoped they had replaced the speaker push connectors but they are still there. The sub crossover for small is 100 HZ or higher but it does not state what is used when large is selected. Is this the same as the XR45? Will post more Later.
Richard
Grayson73
Panny XR45 vs XR50
« Reply #3 on: 14 Apr 2004, 06:30 pm »
When set to large, I believe the crossover only applies to the subwoofer.
Does the SA-XR50 have on screen display?
I too would like to know if it's the same as the SA-XR45.
Richard U
Panny XR45 vs XR50
« Reply #4 on: 14 Apr 2004, 07:12 pm »
Will let you know about on screen display once I hook it up. Will post tomorrow.
Richard
Richard U
Panny XR45 vs XR50
« Reply #5 on: 15 Apr 2004, 05:38 pm »
Bad News,  no on screen display.There is a model called the SA-XR70 that does have on screen display as well as pro logic 2x that is mentioned in the remote control guide. I did a search and could not find any info on this model. Does anyone have any info on this model?
Richard
Grayson73
Panny XR45 vs XR50
« Reply #6 on: 15 Apr 2004, 09:08 pm »
I sent an email to Panasonic US and they said the SA-XR70 would be available on 5/1/04.
