Turntable Wall Mount Blindermann
0 Members and 1 Guest are viewing this topic. Read 2204 times.
doctorcilantro
« on: 8 May 2011, 07:20 pm »
This is the 24" wide model in Cherry. Has a cut out for cable pass-through. Has little rubber dots attached to frame that the wood platform sits on - which you can replace with fat dots etc if you want to experiment. Asking $475 shipped via Paypal Gift. It's a 9 out of 10. A wonderful rack that I was actually going to use for my amp or DAC when the turntable left, but now it's all going.
Quote:
Our platform attaches securely to wall studs which creates a complete isolation from the floor. It is contructed of large gauge aluminum extrusions and heavy duty hardware and attaches to the wall using an extremely robust custom designed bracket. Your turntable will sit on a thick maple platform which is decoupled from the aluminum frame, thereby establishing a vibration barrier.
The wall mount platform is offered in the following sizes:
20.5" wide by 16.5" deep...cost $549
24.0" wide by 18.5" deep...cost $589
27.0" wide by 18.5" deep...cost $609
The weight capacity of a properly installed wall mount turntable platform is 125 lbs.
Stock Photo of maple:
Mine:
doctorcilantro
Re: Turntable Wall Mount Blindermann
« Reply #1 on: 17 May 2011, 12:40 pm »
bump
doctorcilantro
« Reply #2 on: 24 May 2011, 12:07 pm »
bump
doctorcilantro
« Reply #3 on: 27 Jul 2011, 07:02 pm »
bump
rwolters
« Reply #4 on: 28 Jul 2011, 11:36 pm »
PM sent.
Bob
