Mono cartridge vs. mono switch
0 Members and 1 Guest are viewing this topic. Read 2355 times.
Ericus Rex
« on: 7 May 2011, 07:02 pm »
If my preamp has a mono switch is there any benefit to getting a dedicated mono cartridge?
orthobiz
Re: Mono cartridge vs. mono switch
« Reply #1 on: 7 May 2011, 11:10 pm »
Mono stylus is conical? Different head on the cutting lathe...
Paul
jazdoc
« Reply #2 on: 7 May 2011, 11:33 pm »
There is a huge sonic benefit by going with a dedicated mono cartridge.
BaMorin
  • AR turntable rebuilder/modifyer
« Reply #3 on: 8 May 2011, 03:42 am »
Paul
Well, they can be conical if'n y'alls cheap  :P   They make elliptical mono styli as well. Mono is still cut 45deg. Just no vertical cut, only lateral.
Ericus Rex
« Reply #4 on: 29 Mar 2012, 03:26 pm »
I've been thinking of this more and more lately.  I'd like to get some more opinions on my old original topic.
I don't want to drop a lot of dough on a mono cartridge; I'm thinking under $300 new or used.  I don't have any 78s, all 33s.  Contenders in this price range are:
Audio Technica ATmono3 (I think this is a 78 cart though)
Denon 102 mono (I've read that the diamond is not optimized for mono grooves)
Grado ME+ (I've been informed that Grados aren't a good match for my arm - LAD/Jelco - others disagree with this opinion)
Ortofon D25m
What I'm looking for is a cartridge whose diamond is optimally cut for the majority of mono records (33 1/3) out there.  Hopefully this will pull out the most from the groove and reduce the noise floor.  Am I wrong about this?
Now here's the other option.  I have a couple of very good stereo carts; a Benz M2 wood body (with top Soundsmith retip) and a ZYX Fuji (also with top Soundsmith retip).  My preamp also has a mono switch.  Given the level of the carts I currently have and the budget level of the carts I'm willing to buy, am I better off just using the mono switch with my current cartridges or getting a true, albeit a budget, mono cart?
Minn Mark
« Reply #5 on: 30 Mar 2012, 01:01 pm »
I use my preamp's mono switch to listen to 78s (ortofon 78 stylus).
I also found this recent article helpful:
http://www.avguide.com/review/miyajima-premium-mono-be-monophonic-cartridge-tas-213
M
Ericus Rex
« Reply #6 on: 31 Mar 2012, 06:02 pm »
Good review with good info.  Thanks Minn Mark.
I'm guess I'm just gonna have to buy the Ortofon, try it and see if a more expensive mono is in my future.  Maybe that Miyajima eventually.
er
Wayner
« Reply #7 on: 31 Mar 2012, 06:10 pm »
Or you could wear one ear plug........
 :D
