MacBook Pro gets hot
0 Members and 1 Guest are viewing this topic. Read 1269 times.
mikeeastman
« on: 6 May 2011, 08:21 pm »
I,m down loading and converting DSD files, which takes some time and I noticed that the left back bottom of the computer is very warm is this normal or something I should be worried about.
wilsynet
Re: MacBook Pro gets hot
« Reply #1 on: 6 May 2011, 09:24 pm »
I don't know what a DSD file is, but if you're converting stuff, the CPU is usually very busy doing that conversion, and that makes the machine run hot.
In the Applications -> Utilities folder is an application called "Activity Monitor".  Run that and see what may be consuming CPU cycles.
jqp
« Reply #2 on: 7 May 2011, 12:32 am »
you can read on the internet about lots of different laptops that get can get hot, Macbooks are just one of them. I would place the laptop on something that can act as a heatsink (not a heat insulator!), or even get some kind of laptop cooler for the Macbook.
Traditionally you would do this kind of number crunching work (that's really what it is) on a desktop which would hopefully be designed to handle the heat from the CPU or the HD. More and more folks are shunning a good workstation and trying to do everything on a laptop or even a netbook or tablet. But for heavy duty tasks a good workstation-type machine is best.
The new intel chips that are in the Macbooks and now iMacs can really outperform most older desktops, it is that big of a change, and the new chips excel at media operations, and anything really. I think now laptops can be too powerful for their ability to keep themselves cool. The chips are running cooler yet they can do more work than ever, but the laptops manufacturers are just not focusing on heat issues. It cramps the style...even a solid aluminum body may get to hot for comfort.
Can you do so much work that you can fry an egg on a laptop - easily.
mikeeastman
« Reply #3 on: 7 May 2011, 01:29 pm »
The DSD are  1 Bit @ 2.8 mhz files, what ever that means. I'm new to all this, but a 3 min song is  201.7 MB. As for cooling right now I have Mac sitting on 2- 3/4"X 2" sq blocks of sandstone (per corner), would a heat sink made with alternating layers of copper an aluminum sheeting with spaces between them help?
  Thanks for input, Mike
brj
« Reply #4 on: 8 May 2011, 08:12 pm »
Most importantly, make sure that you're not blocking the air intakes or exhausts.
On the current generation MBPs, the intake and exhaust vents are integrated just inside of the hinge on the display, so don't block this from above or below.  (For example, don't run compute intensive tasks with the laptop sitting on a soft, fluffy blanket or bedspread that will block the underside of the vents.)  You will hear the fan ramp up in speed as the CPU gets warmer.  There is a temperature at which thermal shutdown will occur in order to protect the CPU and other hardware from physical damage.  Unless you see this behavior on a regular basis with the vents unblocked, I wouldn't worry about the temperature.
low.pfile
« Reply #5 on: 8 May 2011, 10:32 pm »
They all get hot...just don't put anything insulating below it , or block the intakes and exhausts as brj says.
There is a great free Widget that has been around for a while. iStat Pro
http://www.apple.com/downloads/dashboard/status/istatpro.html
It will show you actual sensor temps and fan speeds. you can cross-check the temp rise with specific processes shown in the Activity Monitor mentioned above.
It works on all 10.4 and newer Mac systems.
