Help Please: SqueezePad can't find Squeezebox Server
0 Members and 1 Guest are viewing this topic. Read 3380 times.
Jazzman53
  • Jazzman's DIY Electrostatic Loudspeaker Page
    • Jazzman's Electrostatic Loudspeaker Page
Hello all,
I'm still rather new to discless and I've been using Squeezebox Server on a Vista Laptop with SqueezePad on my Ipad to control my new SB Touch.  I've had intermittent connectivity problems from day 1 but now it's stopped working entirely:
SqueezePad opens on the Ipad but it can't find and connect to SqeezeboxServer.  Squeezebox Server says it's running and my wireless router appears to be working OK.  I have no idea how to troubleshoot this problem and I need advice for dummies explained as simplistically as possible, as I'm not at all puter-savvy.... HELP!
Pez
Re: Help Please: SqueezePad can't find Squeezebox Server
« Reply #1 on: 6 May 2011, 08:15 pm »
Try installing the logitech controller software on your iPad. See if you have the same problem. From what I understand squeezepad is in it's infancy and may be buggy. Give the logitech controller a shot. If that works better my guess is it's a software glitch.
Jazzman53
Problem fixed (SqueezePad can't find Squeezebox Server)
« Reply #2 on: 6 May 2011, 09:57 pm »
Looks like the problem is solved!  It was as simple as deleting and then re-downloading SqueezePad to my Ipad... it's working fine now.
wilbert-vanbakel
  • Photoshopped Smile
    • On Facebook
« Reply #3 on: 7 May 2011, 03:43 am »
It may help to configure your vista laptop with a static IP address.
ctviggen
« Reply #4 on: 7 May 2011, 10:37 am »
I've done that with my network (assigned every device a fixed IP address), and this has helped a lot.
Jazzman53
« Reply #5 on: 7 May 2011, 12:19 pm »
I'm such a puter dummy... An IP adress is a bunch of numbers?  I'm guessing I would acess some "properties" menu from the control panel on my laptop and the "settings" menu on th IPad... but I wouldn't know how to assign an address
ctviggen
« Reply #6 on: 8 May 2011, 03:04 pm »
An IP address is a set of numbers, like 192.168.1.1.  If you have a wireless/wired router, the easiest thing to do is to use a web browser and connect to the router.  You can do this by entering an address of the router, as follows
http:// 192.168.1.1
(There would be no space between the // and the 192, but it's there to prevent this from becoming an internet address.)  The address could also be 192.168.0.1, or any of several others.
Anyway, when you do this, you would get a login screen allowing you to access the router. If you know your router name, you can download a manual from the manufacturer's website.  There is typically a way to assign each device on your network an assigned address (and you don't even have to care what the address is).
You don't have to do this, but it tends to make the systems more stable if you do. For instance, my wife's computer kept losing our networked printer, so I assigned the printer a fixed address, and her computer hasn't lost the printer yet.
