For Sale: Jamo C803 Bookshelf Loudspeakers
0 Members and 1 Guest are viewing this topic. Read 3849 times.
TjMV3
« on: 3 May 2011, 04:48 pm »
I have a pair of Jamo C803 bookshelf speakers, in the Black finish, $300.00.    I am located in the Salisbury/Rockwell North Carolina area.
The Jamo C803 bookshelf speakers are big bookshelf speakers. These are not your typical, modern little plastic speakers. They are not little flimsy speakers. These are high quality speakers,  they're built like little tanks and are capable of cranking out some killer bass and sound great overall.
Practically new. These speakers function perfectly and are in aesthetically mint condition.
Jamo C803 Specs:
http://www.jamo.com/na-en/products/c-803-description/
System Type 2-way bassreflex
Woofer (mm/in) 180 / 7
Tweeter (mm/in) 25 / 1 DTT
Power (W, long/short term) 125 / 250
Sensitivity (dB, 2.8V/1m) 87
Frequency Range (Hz) 45 - 24,000
Impedance (Ohm) 6
Weight (kg/lb) 9.9 / 21.8
Product dimensions (mm/in, HxWxD) 380 x 225 x 341 / 15.0 x 8.9 x 13.4
« Last Edit: 3 Feb 2014, 12:23 pm by TjMV3 »
TjMV3
Still available.  Great deal on these wonderful sounding speakers.
TjMV3
Thank you,  Phil.
I fixed the link in my original thread starter post.  Appreciate it.
TjMV3
Price reduced to $550.00 for the set.
TjMV3
Just giving it a bump.  Great sounding speakers and a great deal (if I don't say so myself :wink:  )
TjMV3
Re: For Sale: Jamo C803 Bookshelf Loudspeakers
« Reply #6 on: 3 Feb 2014, 12:24 pm »
Bumping this up,  as my Jamo C803 are up for sale,  again.   The center channel is no longer available.   C803 bookshelf speakers,  only.  Thanks.
