Magnolia Time
0 Members and 1 Guest are viewing this topic. Read 1758 times.
Goosepond
  • Virna!
Magnolia Time
« on: 1 May 2011, 06:35 pm »
Well, Mississippi is known as the Magnolia state but the Magnolia is actually our state flower here in Louisiana.
Taken with a Canon 1Ds2 using a 70-200mm F/2.8L IS and a 2X converter for a focal length of 400mm wide open at F/5.6 because of the converter.
Gene
PeteG
Re: Magnolia Time
« Reply #1 on: 1 May 2011, 08:12 pm »
Gene,
Nice picture, your body and lens are also very nice. Why the 2X though.
Goosepond
  • Virna!
Re: Magnolia Time
« Reply #2 on: 1 May 2011, 08:53 pm »
Thanks, Pete.
Well, I live in a wooded area but I can't get close to any of the Magnolia blossoms. So in order to fill the frame, I thought I'd try the 2x. I don't use it often but I thought it was called for in this instance.
I'd love to be able to get close enough to use my 100mm macro lens. I've located a low enough bud that's also close enough to the lane. I'll use my step ladder and see, maybe tomorrow.
Gene
PeteG
Re: Magnolia Time
« Reply #3 on: 1 May 2011, 10:25 pm »
I actually had my 100mmL macro out today, but here it’s still gray looking and no flowers yet.
jqp
Re: Magnolia Time
« Reply #4 on: 16 May 2011, 04:10 am »
Here is one about to pop in Charlotte NC - Sunday May 15 cropped and adjusted from Nikon D90 with 18-200
jqp
Re: Magnolia Time
« Reply #5 on: 24 May 2011, 03:26 am »
Caught this one after Sunday brunch
Goosepond
  • Virna!
Re: Magnolia Time
« Reply #6 on: 24 Sep 2011, 02:33 am »
Well, it's just about time for the Magnolia center thingys to turn to seed.
This one is almost there:
And this one is indeed there:
Gene
tabrink
  • lake life is good
Fall is just around the corner
« Reply #7 on: 24 Sep 2011, 02:42 am »
tabrink
  • lake life is good
Re: Magnolia Time
« Reply #8 on: 24 Sep 2011, 02:46 am »
