Questions regarding updated Choked power supply for Cornet
0 Members and 1 Guest are viewing this topic. Read 1781 times.
library
Jim
I learned simple power part update for Cornet. Below is the part of circuit.
5Y3 #8--Choke(10H)----  R2
..........22uF.............47uF
.......... G    r    o    u    n    d
(Dots are for spacing)
The choke has 10H, 450Ohm DCR. (maybe 60mA max.)
I modified it and it works fine. I have much volume in the lower strings with Cornet octal.
My questions:
1. Are the values of capacitors correct?
2. Since DCR of choke is inserted, should the R2 value be decreased by the DCR value of choke?
Thanks always,
-lib
