Passive sub with intera 80.1 who does the eq work???
0 Members and 1 Guest are viewing this topic. Read 1855 times.
jparkhur
Assuming I connect a 15 inch sub with approp. Box to a 400 watt amp, crossover at 80 hz, would the pre/pro do all the eq work for me if I used the audessey system build in?
Jp
jparkhur
Re: Passive sub with intera 80.1 who does the eq work???
« Reply #1 on: 3 May 2011, 09:42 pm »
Bump for thoughts
flintstone
« Reply #2 on: 3 May 2011, 10:01 pm »
If you use the sub output on the Integra........yes. I use VMPS passive subs in my system with an Onkyo 805.
Dave
