Proper crossover settings for 7.2
0 Members and 1 Guest are viewing this topic. Read 1403 times.
milford3
« on: 29 Apr 2011, 03:42 pm »
Need advice on crossover settings for front speakers and two subs
Mains are Axiom M22's.  Freg Resp 60-22khz
Subs (2)   Aperion 8D    Freg Resp  33Hz-22Hz
jtwrace
    • TIPP YouTube Channel
Re: Proper crossover settings for 7.2
« Reply #1 on: 29 Apr 2011, 03:45 pm »
If you want it to be easy then set it to 80 Hz and adjust by ear.  If you want it "right" then take a look in the acoustic section about measuring with REW or HolmImpulse.
Phil A
« Reply #2 on: 29 Apr 2011, 05:51 pm »
I'd agree with the above.  Rated frequency response does not equate to what you get in all listening rooms.  Besides the factor of the room, bass frequencies sum.  So that if you had a speaker that really did measure 60hz from the listening position, setting the crossover at 60hz would result in a bass bump at around that frequency.  In theory, you would want to set it a hair lower than where the bass drops off, however, the room is the most overlooked audio component.
Bob in St. Louis
« Reply #3 on: 3 May 2011, 01:17 am »
Wise words. I agree.
80 is a great starting point, adjust from there.
Bob
