Nemesis
0 Members and 1 Guest are viewing this topic. Read 1557 times.
JoshK
Nemesis
« on: 1 Apr 2004, 09:25 pm »
Is the Nemesis rear ported or front ported (or down for that matter)?  Asking because I am wondering whether a pair of Nemesises could be mounted to the wall next to my plasma.
popsyr
Nemesis
« Reply #1 on: 2 Apr 2004, 10:17 am »
Josh
The Nemesis has a rear port. They also have a center foot on the bottom which allows you to tilt the speaker, since without the foot the speaker is tilted upward.
Klaus might have some ideas as far as mounting them on the wall.  I think you would have to move them out at least a couple of inches from the wall.
Marbles
Nemesis
« Reply #2 on: 2 Apr 2004, 07:28 pm »
The Circe is bottom ported and only about $200 more for the pair.
They are only about 6" deep.  You might want to consider them if they are tall enough.
If not then maybe some inside the wall speakers would do?
