VDA-2 is back in stock!
0 Members and 1 Guest are viewing this topic. Read 3772 times.
CIAudio
« on: 26 Apr 2011, 07:50 pm »
Many of you have been asking so I figured I'd post it here...
VDA-2 is back in stock.
-Dusty
dminches
Re: VDA-2 is back in stock!
« Reply #1 on: 27 Apr 2011, 12:52 pm »
Dusty, does the VDA-2 oversample input signals "below" 24/192?
CIAudio
« Reply #2 on: 27 Apr 2011, 01:49 pm »
I assume you mean "upsample".
VDA-2 does not upsample...it simply decodes the native signal up to 24/192.
dminches
« Reply #3 on: 27 Apr 2011, 02:58 pm »
Yes, that's what I meant.
I thought that was the case.  Thanks.
CIAudio
« Reply #4 on: 27 Apr 2011, 03:09 pm »
As you've probably guessed, we don't think upsampling is a good idea.
dminches
« Reply #5 on: 27 Apr 2011, 04:40 pm »
And it seems like more companies are starting to share that perspective.
dminches
« Reply #6 on: 27 Apr 2011, 10:27 pm »
Can you explain the difference between over sampling and up sampling?
CIAudio
« Reply #7 on: 27 Apr 2011, 11:05 pm »
There are several articles available on the web that explain this so I won't go into great detail.
Oversampling is used to improve digital filtering.
Upsampling can mean several things...in the case of audio DAC's, it generally means multiplying the native sample rate AND increasing the bit rate from 16 to 24 bits etc.
A mathematical algorithm is used to create what it thinks a 24 bit version of the original 16 bits would look like. It is not possible to "make-up" a new signal more accurate than the original 16 bits.
