need external FM tuner
0 Members and 1 Guest are viewing this topic. Read 4261 times.
Rclark
« on: 26 Apr 2011, 08:03 am »
 For my fiance so she can listen to her radio stations while she's studying. Will plug into my DAC preferably via coax or optical is fine.
 Thank you.
srb
Re: need external FM tuner
« Reply #1 on: 26 Apr 2011, 09:02 am »
There aren't too many FM tuners that have digital audio outputs, as FM is analog and it doesn't make a lot of sense to convert that to digital and then back to analog through an external DAC.
That being said, Cambridge Audio has a 650T AM/FM/DAB tuner at ~$500, NAD an M4 Master Series AM/FM tuner at ~$1300, and McIntosh has an MR88 AM/FM/XM/HD tuner at ~$4000.  They all have coaxial and optical digital audio outputs.
You are probably looking for something less expensive.  There is one strange duck - an Auvio AM/FM/HD tuner that also has coaxial and optical outputs.  It was selling for $40 on Radio Shack's website, but is out-of-stock.  You might be able to find one at a local store. http://www.radioshack.com/product/index.jsp?productId=3899229
Otherwise you can occasionally find one on eBay. http://cgi.ebay.com/Auvio-HD-Radio-Tuner-NEW-/280662459478?pt=LH_DefaultDomain_0&hash=item4158c94456
jtwrace
    • TIPP YouTube Channel
WGH
« Reply #3 on: 26 Apr 2011, 02:22 pm »
I'm a big fan of the Sony XDR-F1HD AM/FM Digital Tuner. The tuner does not have digital out though.
Unfortunately the tuner is discontinued but keep searching and one will turn up, they retailed for $99 when new.
Wayne
RileyD
« Reply #4 on: 30 Apr 2011, 03:59 pm »
doug s.
  • makin' music
« Reply #5 on: 1 May 2011, 04:36 pm »
if you want a hybrid digital tuna, the sony xdr-f1hd sounds better and has better reception than the other h-d suspects mentioned in this thread.  (also has better reception than pretty much any tuna at any price...)  but, it won't sound as nice as as a norrmal (wintage) non-hd tuna.  may not be an issue for casual listening.
re: the (non-hd) tuna jtwrace is trying to sell, i own one and can wouch for its nice performance, but i wouldn't pay anywhere near that much for one...
doug s.
Rclark
« Reply #6 on: 3 May 2011, 01:40 am »
thanks guys  :thumb:
roger15ohm
« Reply #7 on: 24 Jun 2011, 12:00 am »
Hello,  if digital output is no longer your concern,  and size does matter to you,  check this: Pro-ject FM Tuner.   A cigarate box size but looks awesome.  I'd confirm 1 pending payment and will use it for running in my sleepy amps.
Cheers.
