0 Members and 1 Guest are viewing this topic. Read 46285 times.
Just pulled the trigger on this unit: http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=270725567462&ssPageName=STRK:MEWNX:ITwill report back when received and reviewed!
I've been looking at around the same price range, among the others already mentioned there are the HLLY DMK-IV and SMK-III both at around $300, the very few reviews I can find seem very positive, the popular V-DAC, the Yulong DAH1 and D100 that has many many followers.But right now in my wishlist the HEGEL is at the top, followed by the audio-gd's but have not pulled the trigger on any to see if I can stretch that budget a bit I have not heard about this one until now, can you be so kind in telling us how good is the usb next to the other inputs in it, and what exactly do they mean when the say "USB upsampling to 24/96 Hz", is it just bad translation and they meant that the usb supports 24bit/96KHz or if it is a way to hide the fact that it supports only 16/48 and it gets upsampled?
Expecting first "child" (Baby girl) in less than three weeks...
Congratulations! Keep the music spinning. You'll need it to swim through the joy and chaos of parenting. Your child doesn't know the difference, so introduce her to music early and often.I'm going to battery power this DAC and use it with my SB3. Maybe do some op amp rolling as well. Russ
Dang! That is a good deal. Just ordered one myself.
I have Jolida Glass FX Tube DAC. It has a true tube output and is in the $350.00 range. So far I have been enjoying it and rolled some tubes through it. Right now I have some Amprex (HP) labled 12AU7 in it that are very sweet sounding but a little light on bass.
Muse TDA1543 (coax and optical)http://cgi.ebay.com/Audio-DIR9001-4X-TDA1543-parallel-connection-NOS-DAC-S-/270725592140?pt=LH_DefaultDomain_0&hash=item3f0880b44c
Can someone tell me for sure if this dac can decode 16 bit 48khz (eg from dvd's) ? I got the impression that TDA1543 did only 16/44, hence my question.
Can someone tell me for sure if this dac can decode 16 bit 48khz (eg from dvd's) ?I got the impression that TDA1543 did only 16/44, hence my question.Cheers, jaspal.
For it to work you would have to set an option in the DVD player to set the digital output to downmixed 2-channel/stereo PCM (or if the DVD disc itself has a menu option to use a stereo soundtrack, but very few do).Steve
I can report that the single TDA1543 version works with an Apple TV (which outputs 16/48)
