0 Members and 1 Guest are viewing this topic. Read 5419 times.
It will probably have a pair of 7" woofers (which will result in higher sensitivity and greater total cone area for the woofer section).]It will probably have a pair of 7" woofers (which will result in higher sensitivity and greater total cone area for the woofer section) .
Skimp on electronics all you do is skimp on sound
Sounds like a very kewl idea! Being able to use cheaper solid state amps and more reasonably priced tube amps would be an advantage.BobPS That being said, my McCormack 225 does a good job with my SoundScape 10's. They are only about $1300 used on Agon now.
This sounds like a great idea and one very cool speaker! I expect it would be quite popular as most audiophiles can't go above $10,000And skimping on electronics cost doesn't have to mean worse sound. We live in a world where people have budgets. Speakers/room make up 80%+ of the overall sound (so long as the rest of the system meets the basic requirements) IMHO. Spend it where it counts.
What a great amp! I wonder how the newer DNA's perform, such as the 250?
Just so this does not get off track, we currently are working on something and may be able to announce it shortly. However, unless our plans change (and we go back to the drawing board and start over), it will probably not have an 8" woofer. It will probably have a pair of 7" woofers (which will result in higher sensitivity and greater total cone area for the woofer section). But until we have a design we can sign off on, it is all pretty much speculation. So I can't really comment further.- Jim
