F.S. DBX Drive Rack PA with RTA measurement microphone
0 Members and 1 Guest are viewing this topic. Read 777 times.
macrojack
I replaced this DBX with an XTA 224 which has worked out very well. That means one of you can get a deal on this amazing speaker management tool. Both pieces can be had for $400. Both are in as new condition.
If you are a DIY speaker designer, want an upgrade from your Behringer, or just want to bypass the passive crossover in your current speakers, this DBX device can prove to be invaluable. With the accompanying mic, you can equalize your room.
The Drive Rack PA is a crossover, time delay, graphic EQ, parametric EQ, limiter, and subharmonic filter all in one rack space. Speaking of which, unit has never been rack mounted and does not have a mark on it. I am the original owner and I have the original, box with packing materials and extensive owner's manual. You can have a lot of fun with these.
