SB3 analog out problem....
0 Members and 1 Guest are viewing this topic. Read 1873 times.
rtate
« on: 17 Apr 2011, 10:37 pm »
All of a sudden today the output of my SB3 stopped working... :(
I have tried different sources including another SB3 and the rest of the system works fine.
If I turn the volume all the way up I can hear the music very faintly.
Any suggestions on what the problem could be??
rtate
Re: SB3 analog out problem....
« Reply #1 on: 18 Apr 2011, 11:02 am »
I have done the "factory reset" and the "xlinx" reset as well but still no go.
One thing I noticed is that the SB's volume contol has no effect on what faint
sound that I can hear....
Still looking.... :scratch:
BPT
  • Balanced Power Technologies
« Reply #2 on: 18 Apr 2011, 12:20 pm »
Unplug SB3 from power or a few minutes, then power up. Download/reload latest version of Squeezecenter--check your SB3 for any firmware updates.
Chris H.
rtate
« Reply #3 on: 19 Apr 2011, 01:04 am »
I have powered down while doing the factory reset and my server is at 7.5.3.
I don't think it's a server issue because my other SB3 works as well as softsqueeze on my main PC.
mcgsxr
« Reply #4 on: 19 Apr 2011, 01:32 am »
I have been using SB3's for over 5 years now, and have never had this specific issue.
Wish I could help, but I am stumped.
I assume you have tried moving the unit to a different system, and or wiring it by ethernet, and nothing improves?
rtate
« Reply #5 on: 19 Apr 2011, 10:47 am »
Hi Mark... I have not tried the problem unit in another system but have used a second SB3 in the same system with no problems.
The  problem SB has a wireless signal strength of 75-78%.
All functions work properly just very low output... :scratch:
rtate
« Reply #6 on: 23 Apr 2011, 06:08 pm »
As an update I just got a Grant Fidelity tube dac and connected it to the digital out of the SB3 and it woks fine.
So the problem is just with the analog outs... :scratch:
Still looking for the problem....
rtate
« Reply #7 on: 24 Apr 2011, 05:11 pm »
So I did a clean install of my server and lo and behold everything is back to
normal!!
I'm still not sure what the problem was but it's all good now   :thumb:
