0 Members and 1 Guest are viewing this topic. Read 3053 times.
I often find myself at a loss in many of the more technical discussions here in regards to the insides of the gear and what various parts actually do, opamps and triodes and output stages and the like.Describe in as detailed a white-paper format as possible, an audio signal, from inception at the wall socket, to voicecoil. Separate descriptions for both a solid state and tube system please. Describe each part as the signal passes through, what each part does, and how varying qualities of said part can affect the sound. Please describe each part as the signal passes through.
Those are great recommendations by wushuliu
I know it's probably not what you want, but if you want to get the background, you've got to shovel some poop. Here are the books I would start with to get my feet wet:John Lindsey Hood's Art of Linear ElectronicsBruce Rozenblit's Beginner's Guide to Tube Audio DesignHigh Performance Loudspeakers by Martin CollomsSound Reproduction by Dr. Floyd TooleThere are others that are more detailed like Vacuum Tube Amplifiers by Morgan Jones, Earl Geddes' Audio Transducers but that's like learning how to fly the space shuttle without even knowing how to fly a Cessna...It will also seriously influence your purchase and buying decisions for your audio future, hopefully, for the better .Best,Anand.
I like this idea: "relevant knowledge can be distilled into a shorter form suitable for audiophiles." A suggestion for JohnR. Instead of taking on the entire task yourself, consider taking the lead on writing an outline of topics that should be covered. Post the outline here for others to expand on or to critique. When that's settled, individuals can volunteer to write sections (or to collaborate with a few others on that section) that you can then organize into a single document. I do a fair bit of collaborative writing at my day job, and that's often how we approach longer pieces.Just my two cents.Bob
The tough part will be curbing the infinite digressions and tangents both technical and otherwise that immediately follow these kinds of attempts.
