silk purse part 2
0 Members and 1 Guest are viewing this topic. Read 945 times.
rlw3
silk purse part 2
« on: 15 Apr 2011, 10:23 pm »
   So i knew i would need more and i wanted to move them around a lot i decided to pick up some 246, 244 bass traps and 2 Q7 diffusers from GIK. I put a 246 sideways on the ground in back of the speaker next to the front wall. this worked better than standing them up. bass got better. i put another set of 246s behind my listening position on that 42" and finally a third set went on the sidewall directly next to speaker 18" off the ground. bass got better. directly next to the  246 on the sidewall is a 244. then next at the reflection point for the near speaker(right wall/right speaker) is a q7 diffuser. then next is another 244 at the reflection point for the other speaker. then comes the 2 RFZs on each side which are 2.5" thick. With all of these butted up against each other sidewall treatment runs from a few inches in back of the speakers to 16" behind me
