MONOGRAM: Mono Phonostage based on Cornet
0 Members and 1 Guest are viewing this topic. Read 9834 times.
hagtech
« on: 31 Mar 2004, 01:16 am »
Instructions for building this DIY project are now online.  Monogram is an all-tube mono phono stage with variable EQ for 78s and other pre-1955 recordings.  It includes a built-in linestage with volume control, so all you need is a power amp.
The complete article and instructions (742k pdf) can be downloaded at:
http://www.vacutrace.com/pdf/monogram.pdf
Happy building!
jh :)
library
Nice
« Reply #1 on: 31 Mar 2004, 10:24 am »
I found several 78 LPs today. Nice solution just in hand! Thanks, Jim.
hagtech
« Reply #2 on: 1 Apr 2004, 03:11 am »
For those of you who hate tubes (yeah, right), I will soon introduce the "Bugle Pro", an opamp-based phono with the same type of variable EQ.  It will be stereo capable but with a mono switch, so you can also use it for modern playback.  No volume control.
Bugle Pro will be available as 1/2-kit; probably run you $200 total part cost.  Will include finished front and rear panels with printed graphics so your chassis will look professional.  Assembled version $395.  Available in May.
jh :)
Brian Clark
    • http://www.sempermusica.com
Octal Monogram
« Reply #3 on: 28 Apr 2004, 06:12 pm »
Jim, is there an octal version in the pipeline  :?:
Brian.
hagtech
« Reply #4 on: 29 Apr 2004, 04:43 am »
I wasn't planning on doing an octal version.  Too many other things going on.  If you make one, let us know!
jh :wink:
Brian Clark
« Reply #5 on: 29 Apr 2004, 08:40 am »
Fair enough Jim  :wink:
You're doing good work and I am about to build your Octal Cornet into my integrated 801A amp. The Monogram would be a stand-alone.
I guess the paralleled 12AX7 can be replaced with one section of a 6SL7 and the 12AU7s are then simply replaced by 6SL7s and that's it....
Thank you for sharing your circuits, they are a refreshing change from the endless recycles from yesteryear.
All the best
Brian  :)
woodsyi
« Reply #6 on: 8 Sep 2005, 03:51 pm »
Hello Jim,
I just got about 300 78's dating back to 1902.  Can you put together a monogram phono pre assembled?  I have too many project going on and I don't want to start yet another DIY project.  If so, how much?
