Torus Power- new to brand- had a few questions.
0 Members and 1 Guest are viewing this topic. Read 1524 times.
Heckler75
« on: 11 Apr 2011, 01:05 am »
Looking  at  getting  a  Torus,  had   a  few questions.
what is  the performance difference, between   "RM15"   and  "CS15 AVR"    (performance wise)
and can it   be order  online  from  "AudioAdvisor"
USA   retail   price  for each...
with  the Torus PC,  should   my  sources   pre/amp/blu ray and etc...  Run  dead  silent       No  background noise.   at idle  or running
sorry  for all   questions,   very new to product.
current  setup:  BP26-4BSST2-BDA1- BR PLAYER- SAT BX- TV
have  separate outlets  for  amp  and pre
rest  of  stuff   connected to  a  panamx 5300
AC  is   a  awesome  forum
Dan
  • The Demo is Everything!
    • http://www.bryston.com
Re: Torus Power- new to brand- had a few questions.
« Reply #1 on: 11 Apr 2011, 09:10 am »
Hi Dan
The RM is Rackmount and the CS is consumer 17 inch faceplate.
Audio advisors sells the Bryston BIT units now which replaced the Torus units. The Bryston BIT has a faceplate to match the Bryston gear and is the same internally as the Torus.
The unit is called the BIT15.
James
« Last Edit: 11 Apr 2011, 02:15 pm by James Tanner »
Heckler75
« Reply #2 on: 12 Apr 2011, 03:07 am »
Hi James,
thanks,  and looks great....
had  a  question, about  the Bit 15,  when all   my gear  is  connected (BP26/4Bsst2/BDA etc...)
when all   the gear  is  connected,    should  all  the sources be dead silent, and even at idle..
No  hum or  hissing   thru speakers.
 does the BIT 15,    cancels all  background  noise,   of any kind.
want to make sure before  ordering...
new  to  the Bit 15 / torus power
Danny
« Reply #3 on: 12 Apr 2011, 03:17 am »
Hi Danny,
The Torus eliminates noise at the input to your gear, not the output.  So noise through your speakers would be noise from your components.
james
