What Are The Chances???
0 Members and 1 Guest are viewing this topic. Read 1009 times.
Fullvolume
« on: 9 Apr 2011, 12:40 am »
I just hooked up my new BP1.5 and the right channel does not come on. Switched all the lefts to rights and rights to lefts and it looks like it is the right channel of the Concept turntable...I even hooked up the old phono preamp and the same thing....the left side turn table will work in left/right speakers....any ideas???
« Last Edit: 9 Apr 2011, 09:59 am by Fullvolume »
  • The Demo is Everything!
    • http://www.bryston.com
Re: What Are The Chances???
« Reply #1 on: 9 Apr 2011, 10:47 am »
You could reverse the leads on the cartridge to see if it's the cartridge or the tonearm cable?
James
